K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
pistons
Old Feb 18, 2007 | 05:45 AM
jmja9281's Avatar
jmja9281
Default pistons
I am looking for some pistons for a 92 shadow 2.5. Dose anyone know where I could locate some on the internet. Thanks
Old Feb 18, 2007 | 03:17 PM
89Daytona's Avatar
89Daytona
Default RE: pistons
http://www.partsamerica.com/ProductL...=Piston+-+Cast
Advance Auto/Kragen/Checker/Schucks/Murray's has them for $17-140
Old Feb 19, 2007 | 05:04 AM
jmja9281's Avatar
jmja9281
Default RE: pistons
Thanks for the links 89Daytona. What about a 4 speed auto tranny, do you know if this set up would be compatable even though mine has a falling 3 speed.
Old Feb 19, 2007 | 11:17 AM
speedyshelby's Avatar
speedyshelby
Default RE: pistons
4 speed would just give better mpg. The 4th speed is overdrive and if like my dads dakota 4 speed it won't shift into it until 105 ish don't ask how I know he was driving it. I don't think they offer a 4 speed for 2.5 2.2. The only one I know of is the one for v6s but that won't bolt up to your motor and wouldn't want anyways.
Old Feb 19, 2007 | 02:45 PM
89Daytona's Avatar
89Daytona
Default RE: pistons
Info on the transmissions ---> http://www.allpar.com/mopar/transmissions.html
If your 4 speed isn't shifting until 105mph, the gears are wrong or your transmission is built/programmed correctly
Old Feb 19, 2007 | 10:10 PM
speedyshelby
Default RE: pistons
Drive it like a normal it will shift at 45 to 50 ish. Keep it to the floor then you get 105 thing. Both dakota are 4.7 with the stock trans both do it.
Old Feb 21, 2007 | 04:08 AM
jmja9281's Avatar
jmja9281
Default RE: pistons
Well my shadow came with a3 speed. Sometimes it catches the last gear, mostly not. I cruise around town at 4,000 RPM's. Was just intrested in 4speed for the extra gear, Will probably just dropin a 3 speed. This tranny has been rebuilt already 3 times in last 7 years. For some reason or other the same situation accurs. Thanks speedyshelby/89Daytona for the info it helps.
Old Mar 2, 2007 | 04:20 AM
EZE0143's Avatar
EZE0143
Default RE: pistons
HEY CHECK YOUR TRANNY COOLER THEY TEND TO CLOG REDUCING FLOW WITCH THEY RUN HOT AND BURN UP SLOWLY I WENT THROU IT TWICE BEFORE KNOWING IT IN MY 86 LEBARON 2.2 TURBO 3 SPEED
