My 2001 Ram 1500
Old Mar 25, 2010 | 09:12 AM
OSUdodge's Avatar
OSUdodge
Default My 2001 Ram 1500
2001, White/Grey, 5.2L, 4x4, Reg Cab Short Bed
Her Name is Daisy Mae.
-33" Dunlop Mud Rovers (pictures show BFG's.. I just switched)
-Two 4' Black Whips linked to a Uniden Unit
-Dual Radio, Rockford Fosgate Amp, Single Polk Audio Sub (bolted to floor)
-Projections Lights (still need to be tweaked)
-Flowmaster Super 44.
Still to come:
-Electric Cooling Fans
-Removing Badges
-Cold Air Intake???
-Custom Front bumper
Thanks For looking. Love the forums here!!
Old Mar 26, 2010 | 08:31 PM
jackdup ram's Avatar
jackdup ram
Very nice!, did those projection head lights come with mounting brackets? or do you have to use the stock brackets from the original head lights? I am lookin at gettin the same for my ram but the brackets have had better days, to much wheelin!
Shawn.
Old Mar 28, 2010 | 08:35 PM
OSUdodge's Avatar
OSUdodge
They came with new brackets. Direct swap, I think 3 bolts each? The halo's require some extra wire splicing but its easy. Also because the stock lights are one bulb for highs and lows and now there is two there is a mix up with wiring and the brights aren't very bright, and my bright indicator is always on, on my dash. I found the fix on a cummins forum I just havent attempted it. Also because the front end pointing down I have to aim them way up, so they don't look exactly perfect against the qtr panel. I think a leveling kit should fix that. It doesn't look like you'd have that problem. Nice Rig btw.
Old Apr 16, 2010 | 04:30 PM
jackdup ram
Awesome, thanks for the info!, I should be picking mine up soon, my drivers side turn signal is cracked, I may just say screw it and buy the GTO black out covers and call it a done deal though!
Shawn.
Old Apr 18, 2010 | 10:12 AM
lastrights's Avatar
lastrights
my projection headlights have to splice the hot wires with the led and the halo, if the indicator light is always on then need to do some switching of wires. also you may check your headlight fuses under hood also i fiqured out mine was blown because my projection light was so dim.
Old Nov 3, 2011 | 09:33 PM
DodgeItRamIt97's Avatar
DodgeItRamIt97
Nice truck! If you looking for another front bumper the ones road armor makes look so awesome, make your truck look like a tank.
