Lowering Springs Install!!
RE: Lowering Springs Install!!
They arent really all that hard, I put some on my sxt, and they were a 2 inch drop. All you really need is a sring compressor and vise grips, due to the shaft spinning when you try to unbolt the top nut, and when you tighten it, course you want to put a cloth inbetween the vise grips and the shaft so you wont scar it. And like they said in another post if its a 2 inch drop you'll need to check alignment on all 4 tires.
