wot????
Old Apr 12, 2007 | 05:50 PM
emilysrt's Avatar
emilysrt
Default wot????
ok sorry for this dumb post, but i was wanying to know exact what wot means! i think i know but i am not sure. is it when you never take your foot off the gas and your banging gears? sorry again but i have only had a turbo car for 5 weeks! thanks emily!
Old Apr 12, 2007 | 06:38 PM
prpaster's Avatar
prpaster
Default RE: wot????
Wide Open Throttle
Old Apr 12, 2007 | 06:40 PM
monstab757's Avatar
monstab757
Default RE: wot????
WOT simply means wide open throttle. Its when you got the pedal to the metal babe! Now there is a boost hold feature with Stage 1,2,3 upgrages that allows you to shift during WOT and you can hold boost if you do it fast enough.
Old Apr 12, 2007 | 07:28 PM
emilysrt's Avatar
emilysrt
Default RE: wot????
ok so its me never taking my foot off the gas when i shift? is it hard to do and does it really make a difference?
Old Apr 12, 2007 | 08:08 PM
PSI Chick's Avatar
PSI Chick
Default RE: wot????
yes it really makes a difference. is it hard to do? not really, but if you pull the clutch too quick you'll grind and over time that will do some damage.
Old Apr 12, 2007 | 08:43 PM
silverblacksrt4's Avatar
silverblacksrt4
Default RE: wot????
then why even do it?? unless u racing!
Old Apr 12, 2007 | 09:49 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: wot????
yup, only do it if your ***** to the walls accelerating or dragging. it works a little with S0, but better with other stage upgrades, as S0 tends to let go of the boost rather quickly and without hesitation, but you can still keep some of the boost on S0 doing WOT shifting. although i do not wot shift 1 to 2nd, due to traction issues.
Old Apr 12, 2007 | 11:29 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
Default RE: wot????
Wide Open Throttle shifting is a technique used when your preparing to buy a new clutch or tranny. My buddy BigfaceFMIC is working on his 3rd tranny thanks to WOT shifting...ask him about it.
Old Apr 13, 2007 | 12:17 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: wot????
LOL!!!!!
Dusty
Old Apr 13, 2007 | 04:44 AM
PSI Chick's Avatar
PSI Chick
Default RE: wot????
sounds like someone doesn't know how to drive. i have over 150 passes on my clutch and tranny and not a single problem caused by wot shifting.
