Clutch Stages?
Old Apr 15, 2007 | 07:51 PM
05SRTStage3's Avatar
05SRTStage3
Default Clutch Stages?
I was wanting to know how much horsepower and how much torque each clutch stage can hold? I just need one that is compatible with and that can handle at least 350 lb ft and 350 horsepower! And what brand would be good. And does a lightweight flywheel really make that big of a difference? And another question how much will be safe to lower it with 17 inch wheels and a 225/40 tire? I don't want to sacrifice the smooth ride if I don't have too. And would lowering springs be efficient enough and would I have to purchase any part along with them to make them work. Any suggestions will be greatly appreciated!!!
Old Apr 16, 2007 | 01:30 AM
silverblacksrt4's Avatar
silverblacksrt4
Default RE: Clutch Stages?
i'd go with clutchmasters for sure..
Old Apr 17, 2007 | 11:57 PM
05SRTStage3
Someone else has to have input I really need suggestions on this...Please help.....
Old Apr 18, 2007 | 04:08 AM
PSI Chick's Avatar
PSI Chick
go to each clutch's manufacturer's website. the "stage" clutches are not universal so each company will have different ratings.
Old Apr 18, 2007 | 09:14 PM
05SRTStage3
I think that I have decided on the ACT Street Clutch Kit that is good for 470 lb ft and i have heard that it is very good on the street as a daily driver. So thanks for the help just one more thing.....the lowering springs what would be a good height without sacrificing the ride and would i have to buy anymore parts to make them work correctly besides the spring????
Old Apr 18, 2007 | 10:03 PM
silverblacksrt4
i have eibach and they lowered it where it looks nice but its not scraping on every little bump and what not....
eibach lowers i think 1.6 and 1.8.. not sure but its close to that!
Old Apr 19, 2007 | 04:40 AM
PSI Chick's Avatar
PSI Chick
you'll need new shocks eventually, springs blow them.
Old Apr 19, 2007 | 10:18 PM
05SRTStage3
Ok thanks that is the ones that i was looking at what size wheels and tires do you have.....I have 17' 7.5 wide with 215/40 tires....I would like to get 235/40 Drag Radials would you know if they fit?
Old Apr 19, 2007 | 11:06 PM
PSI Chick's Avatar
PSI Chick
not on the stock suspension
