Advise plz
Old Apr 18, 2007 | 11:30 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Advise plz
actually, depending on conditions, you can hold around 14 stock.
snappy arent we?
and did it really take 2 posts 2 minutes? thats why there is an 'edit' button
edit:
just checking... yup, the edit button still works
Old Apr 18, 2007 | 11:34 AM
emilysrt's Avatar
emilysrt
NO YOU CANT BABY SO GET THAT RIGHT!!!!!!!!!!!!!!! OH YOUR RIGHT IT DOES WORK *******! ANYWAYS THERE IS NO STOCK SRT-4 THAT CAN HOLD 14-15PSI WITH THAT 4 POUND SPRING IN THAT ****TY WG!! SO DONT EVEN TRY IT !
Old Apr 18, 2007 | 11:37 AM
flamingpinhead
Section Moderator
disconnect the battery and reset the computer, it will let you hold just a little bit more boost until the computer readjusts itself. its the cheapass way of holding a little more
Old Apr 18, 2007 | 11:41 AM
emilysrt's Avatar
emilysrt
LOLOL omg that is the way to not spend any money and be cheap! buy a 150.00 wga retard!! oh by the way when you do that it last for like a day if that! so LIKE I SAID THEY DONT HOLD 14PSI STOCK!!! NOT TO REDLINE THEY DONT! WHEN YOU BUY IT FROM THE DEALER TO THEY TELL YOU TO RESET THE BATTERY AND TO DO IT?? I DONT THINK SO! THATS NOT HOW THE CAR COMES STOCK! IF IT CAME STOCK HOLDING 14PSI TO REDLINE YOU WOULD NOT HAVE TO RESET THE BATTARY! OMG LET ME GUESS YOU DO THIS EVERYDAY CAUSE YOU CAN BUY A WGA ? I HAVE ONE IF YOU WANT IT!
Old Apr 18, 2007 | 11:42 AM
emilysrt's Avatar
emilysrt
( CHEAPASS) UMMM WHAT? lol lol. so let me guess you do this right befor you race someone? and it only last for like a day if that! its not the wg holding the boost retard! its just cause the ecu was rest!
Old Apr 18, 2007 | 11:44 AM
emilysrt's Avatar
emilysrt
hey this is emilys man and dont talk **** to my car,cause she knows what she is talking about! you made her upset *******! i am out!
Old Apr 19, 2007 | 03:47 PM
monstab757's Avatar
monstab757
PSIchick. You talk about getting a wideband once you start adjusting boost levels. I just upgraded to a Stage 1 ecu. Should I be concerned with a wideband yet or can I count on the ecu to manage my a/f ratio?
Also, is installing a wideband just allowing you to monitor a/f ratios or can you actually adjust them to prevent running too lean/rich?
Old Apr 19, 2007 | 10:11 PM
05SRTStage3's Avatar
05SRTStage3
I am sorry but yeah it DID hold 14 psi to redline. And no the gage was broken at one point it time it would only read 6 psi but even after it was replaced.....14 PSI TO REDLINE WOW it is possible and I agree with psi chick not every car is the same.....but mine HELD 14 PSI TO REDLINE
Old Apr 20, 2007 | 02:56 AM
flamingpinhead
Section Moderator
if you can not hold at least 13psi stock... you need a tuneup. just did so yesterday evening
and as for the battery disconnect trick... im not going to go through reseting my system just to have an extra 3hp for a day.
ORIGINAL: emilysrt
haha, im sure you MISTYPED it... since you already know that the SRT comes stock with a 7lb spring
ORIGINAL: emilysrt
yes, every time im at a redlight, i hop out and do this to my battery... no better yet, actually i have a switch under the dash that dosconnects the battery power, so i dont even have to get out
and the ecu controls the boost??? duh... see the above post about the 7lb spring.
ORIGINAL: emilysrt
good, can you make her go away for good? someone is sooo sensitive they cry over an internet forum?
i do believe emilysrt is going to meet my block button. have a nice day
Old Apr 20, 2007 | 02:28 PM
sexySRT04's Avatar
sexySRT04
drama wow...
