Advise plz
Old Apr 20, 2007 | 02:42 PM
  #21
PSI Chick's Avatar
PSI Chick
Default RE: Advise plz
ORIGINAL: monstab757
PSIchick. You talk about getting a wideband once you start adjusting boost levels. I just upgraded to a Stage 1 ecu. Should I be concerned with a wideband yet or can I count on the ecu to manage my a/f ratio?
Also, is installing a wideband just allowing you to monitor a/f ratios or can you actually adjust them to prevent running too lean/rich?
if you're changing boost and taking away controll of boost from the ecu it can't control anything. i always advise people to get a wideband as soon as they start to adjust boost levels at all, you'd be surprised how quickly these cars can go lean on you and you don't even know it. the ecu is only designed to control fuel based on stock psi levels, and once you remove it from the boosting equation it has no idea what's going on and can't really adjust fuel accordingly. so don't count on the ecu, it's smart but it's not that smart.
widebands just let you monitor a/f's. you need a seperate unit to control fuel (dtec, neo, etc.). unless you've done some kind of fuel system upgrade (pump, injectors, return line, whatever), you're not really going to have much to control. without those upgrades you have to change boost levels to adjust a/f's. one you do some fuel upgrades though and get a fuel controller, you can pull fuel to tune.
Old Apr 20, 2007 | 04:33 PM
  #22
monstab757's Avatar
monstab757
Thanks PSI Chick. Its good to know that someone actually answers questions on these forums.
Old Apr 20, 2007 | 05:33 PM
  #23
PSI Chick's Avatar
PSI Chick
glad to help
Old Apr 20, 2007 | 07:10 PM
  #24
Plan B's Avatar
Plan B
ORIGINAL: 05SRTStage3
I am sorry but yeah it DID hold 14 psi to redline. And no the gage was broken at one point it time it would only read 6 psi but even after it was replaced.....14 PSI TO REDLINE WOW it is possible and I agree with psi chick not every car is the same.....but mine HELD 14 PSI TO REDLINE
I too was holding 14psi stock as well.......
