srt-4 lasting!
Old Apr 17, 2007 | 11:11 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: srt-4 lasting!
Yes, the average driver will go thru a stock set of plugs every 6-7K miles. More expensive plugs will last longer. When you change the tranny fluid, you should also add the Mopar additive. Also, be sure to use coolant that is compatible with the type specified in the owner's manual.
Dusty
Old Apr 18, 2007 | 02:07 AM
silverblacksrt4's Avatar
silverblacksrt4
wow its been 13k i better change it.. the additive?? where u get that and what is it
Old Apr 18, 2007 | 02:16 AM
motorboy1's Avatar
motorboy1
Mopar ATF friction modifier. From the dealer is probably the easiest place. Some people swear by it some don't, your choice I guess. I put it in mine!
Old Apr 18, 2007 | 03:30 AM
SMTYLEZ's Avatar
SMTYLEZ
OK SO I HAVENT CHANGED MINE IN OVER 15K MILES...CHANGE JUST THE PLUGS OR THE WIRE ALSO...
Old Apr 18, 2007 | 03:33 AM
SMTYLEZ's Avatar
SMTYLEZ
LOL MAYBE THATS WHY I DONT HOLD 16 PSI NO MORE....J/K SPARK PLUGS HAS NOTHING TO DO WITH BOOST....DOES IT[sm=insomnia.gif] LOL?
Old Apr 19, 2007 | 01:24 AM
srtratblock's Avatar
srtratblock
I better change my tranny fluid, changed it when I had 18,000 on it. went with a good synthetic, now I have 58,000 on it. pulled the rubber plug on tranny,drain a little out, looked like it was just changed, had the same color to it, and it didn't have a burnt smell to it. But I better be safe than sorry and go ahead and change it.
Old Apr 19, 2007 | 01:38 AM
srtratblock
I ran my plugs between 25,000 to 28,000 never had any problems except the gap to wide, and mabye one where the electrode breaking down, better start changing minesooner.
Old Apr 19, 2007 | 04:13 AM
waylon's Avatar
waylon
Member
I have 80k miles on my '03 and havent changed the plugs in probably 45-50k miles. I did have the #4 plug problem when i first got it and after they fixed it the second time with the different plugs its run fine.The car is bone stock and as of yet that has been the only problem ive ever had with it.
Old Apr 19, 2007 | 01:36 PM
AirWolf's Avatar
AirWolf
All depends on how well its maintained and not beaten to death . Just take really good care of your srt4 and you dont have to worry.
