Kinetic TB
Old Apr 23, 2007 | 05:31 PM
Aceburner's Avatar
Aceburner
Default Kinetic TB
I got my hands on a Kinetic TB. Are these TB's gud? It's brand new and all. I've heard a couple gud things about them. I wanted to know b4 I went ahead with the buy.
Old Apr 23, 2007 | 05:44 PM
PSI Chick's Avatar
PSI Chick
Default RE: Kinetic TB
awesome tb's. just be sure if it's a newer one or the older style. the old ones leaked, but were fixable. you had to take it apart and put some sealant in and it was good to go.
Old Apr 23, 2007 | 06:54 PM
Aceburner's Avatar
Aceburner
Yes, I'll make sure I ask if its a newer model or not. I'll be buying onr today. Thanks, and now that I remember it, I asked u b4 about these. Sweet!
Old Apr 28, 2007 | 07:21 PM
Aceburner's Avatar
Aceburner
I did get the TB and found out that it was the newer model. Can u tell me how hard are they to put on or anyone?
Old Apr 30, 2007 | 03:39 AM
PSI Chick's Avatar
PSI Chick
they're very easy to install. bascially just take off the vacuum line, disconnect it from the pipe and manifold and pop the new one on. that's really all there is to it, once you start poking around at it under the hood you'll see where everything goes. only real tricky part is getting the throttle cable back on, and that's not even really that hard.
Old Apr 30, 2007 | 11:30 AM
Aceburner's Avatar
Aceburner
Ah, thanks much PSI Chick. Just wanted to know just in case there was sum hard part of the install. I can't wait. Now it'll be off to buing CO's and Wheels, then W/I.
