wastegate question
Old May 5, 2007 | 09:21 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: wastegate question
it monitors your a/f ration, to make sure you arent going too lean. just a standard pod gauge, some of them can get pretty fancy with flashing lights... but others are just a needle that bounces around.
i think it was this one some guys on srtforums were doing a group buy on a little while back, not sure what ever came of it:
http://www.modernperformance.com/all...wideband.shtml
or just a basic a/f gauge
Old May 19, 2007 | 05:26 AM
BLKSRT4's Avatar
BLKSRT4
Yeah so whats an easy way to get of that half throttle boost? cause all i have is CAI, and a boost controller. and its really bad. should i just go back to no boost controller and just have some other stuff done to it instead?>
Old May 19, 2007 | 06:16 PM
PSI Chick's Avatar
PSI Chick
you do not want to waste your money on the mopar a/f, it's a narrowband and is nothing more than a light show.
blksrt4 - you have two options to get rid of ptb. go back to stock or get a big turbo. other than that just get used to it. you should have an aftermarketwga on there though, the stock wga isn't strong enough. you probably need to lower your boost as well.
Old May 21, 2007 | 07:04 AM
BLKSRT4's Avatar
BLKSRT4
and if i turn my boost controller all the way down. will it help with the PTB. and to go back ti stock will be alittle difficult. considering i have the aftermarket boost controller. and i had to run new lines and crap. would it just be a better idea to go back to no boost controller?
Old May 21, 2007 | 02:17 PM
PSI Chick's Avatar
PSI Chick
no. a properly set boost controller actually reduced ptb.
Old May 21, 2007 | 08:53 PM
BLKSRT4's Avatar
BLKSRT4
then how do i properly set it. cause no matter what i turn it too. it does the exact same thing everytime.
Old May 22, 2007 | 03:04 AM
BLKSRT4's Avatar
BLKSRT4
hey. can anyone show me a diagram of the pressure lines for turbo lines that go to the turbo and the boost controller. and the wastegate. cause i need to hook all the lines back up. since i took off the boost controller.
Old May 22, 2007 | 03:18 AM
PSI Chick's Avatar
PSI Chick
there's a vacuum line diagram on your hood, just follow that.
to properly set a wga/mbc on most cars - set the wga to about 11-12psi and increase the boost from there with the mbc.
Old May 23, 2007 | 08:28 PM
BLKSRT4's Avatar
BLKSRT4
well i took the boost controller out. and i ran new lines. and it hold at 14 psi. so i think i did a pretty good shoyuld considering i didnt get anysleep. i was up all night and all morning cause i kept being distracted away from my car. well thanks psi chick for the help.
