WheeL HoP
Old May 19, 2007 | 09:16 PM
T_U_R_B_O's Avatar
T_U_R_B_O
Default WheeL HoP
WhiCH MoToR MounTs ShouLD I gO WiTh To HeLp PreVenT WheeL Hop
ThankS GuYS
Old May 19, 2007 | 10:11 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: WheeL HoP
I'd go with Prothane for about $24....you get a choice of Street or Race versions....
Dusty
Old May 20, 2007 | 12:34 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
would get the street ones though. too stiff can cause other problems from vibration
and keep your finger off the shift button, the random caps make it hard as hell to read
Old May 20, 2007 | 04:04 AM
lblackneon's Avatar
lblackneon
ORIGINAL: flamingpinhead
other problems like what? i have the race ones. if they really would cause problems i'll switch to street.
Old May 20, 2007 | 05:08 AM
flamingpinhead
Section Moderator
its been discussed before, the added vibration is rough on your car. u can feel it in the steeringwheel before/after. nothing too terrible but perhaps vibrating things loose, added noise and highly annoying. youll still get added vibration from the inserts though, just not as bad. its honestly more of a personal preference. basically they just stop the motor from moving as much. so what isnt absorbed is transfered right to other areas. stiffer mounts mean less absorbtion, thats all.
Old May 20, 2007 | 03:49 PM
PSI Chick's Avatar
PSI Chick
get a set of dogbones if you're serious
Old May 22, 2007 | 02:10 AM
Wolfish's Avatar
Wolfish
ORIGINAL: PSI Chick
X2
Better tires and a set of bones make all the difference in the world. It feels pretty good when you know the powers' going where it's supposed to.
Old May 22, 2007 | 04:40 AM
flamingpinhead
Section Moderator
are the dogbones gonna make you vibrate your brains out?
Old May 22, 2007 | 10:50 AM
SRT_YA's Avatar
SRT_YA
depends on how well your brains are in there
I am only speaking from what I've read (on that OTHER forum)... YES... you will notice a lot more vibration.
As Amy and I have "chatted" before - it's all relative to what you can stand or mind. Me, I will be going with motor mount inserts for now (my car is still street driven and I want my A/C to work and not rattle my teeth out when it's on!)...
Old May 22, 2007 | 01:01 PM
PSI Chick's Avatar
PSI Chick
[sm=smarty.gif]i don't notice any vibration in my car
