ignition control module
Old May 21, 2007 | 01:49 AM
z.e.r.o.herrle's Avatar
z.e.r.o.herrle
Default ignition control module
i have a 2004 srt4 and i am getting an engine code about my ignition control module. i was told that my turbo timer could have had a wire come loose but i traced my wires and i found no disconnection anywhere. my #4 plug wire and connection on my coil are bad as well. what could be causing the problem with my ICM. plus i dont know where it is located.
Old May 21, 2007 | 02:21 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: ignition control module
Your #4 plug wire is famous for melting down if it is an early model year number. All'03swere the same way. I upgraded my plug wires to MSDs and plan to finish it all out before the summer heat hits here......check modernperformance.com for a MSD coil pack for about $70......
Dusty
Old May 21, 2007 | 02:47 AM
z.e.r.o.herrle
i have an msd ignition system. i even have the heat sheild. another code that has appeared is one for my asd relay control circuit and p0688.
Old May 21, 2007 | 04:18 AM
PSI Chick's Avatar
PSI Chick
are you talking about a dis-2?
Old May 21, 2007 | 04:34 AM
z.e.r.o.herrle
im not sure what a dis-2 is.
Old May 21, 2007 | 02:16 PM
PSI Chick's Avatar
PSI Chick
ok then what msd product are you using? the only msd icm that works on our cars is the dis-2. if you're using something else then that's the problem.
Old May 25, 2007 | 01:39 AM
z.e.r.o.herrle
that is what i am using. come to find out my computer fritzed out and i have to reprogram it. its not my icm that messed up, it was my ecm/pcm. my scanner is messed up and i read it wrong.
Old May 25, 2007 | 04:30 AM
PSI Chick's Avatar
PSI Chick
if your ecu was fried your car wouldn't be starting or running.
