stock wastegate ?
Old Jun 1, 2007 | 11:45 PM
Polishguy33's Avatar
Polishguy33
Default stock wastegate ?
ok so i pretty sure eveything on my car is stock. im having a problem though with overboosting though. im boosting 19-20 and falls off to 15-16 till redline. i got the overboost code but the check engine light went away. the code is still in the computer though. any body know what the problem might be. i would really apreciate any help cause i really want to go tothe track again soon.
Old Jun 2, 2007 | 09:37 AM
redevil's Avatar
redevil
Default RE: stock wastegate ?
do you have a boost controller?if so turn the boost down a lil bit, you'll still hold 16 psi, I never had an overboost problem so thats all i can tell you.
Old Jun 2, 2007 | 12:17 PM
Polishguy33
nope no boost controller
Old Jun 2, 2007 | 01:57 PM
Burnnout's Avatar
Burnnout
On the end of the wategate arm is there a nut ?
Old Jun 2, 2007 | 02:38 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
just curious, where does your boost gauge rest when the car is off?
Old Jun 2, 2007 | 03:34 PM
tyler819's Avatar
tyler819
i have that same problem, in 2nd gear it boosts to 17-18psi then falls back to 15 like he said. then in 3rd gear it goes to like 19-20psi then falls back to 15 again.....
Old Jun 2, 2007 | 06:24 PM
Polishguy33
no i dont see a nut on the wastegate. im pretty sure its the stock one. it startedhappening after i tightened all the air hose clamps. then i took the negative off of the battery to reset the ecu. at first i thought is was normal cause the computer had to relearn every thing. but i had the problem for a couple weeks now.
Old Jun 2, 2007 | 06:25 PM
Polishguy33
oh and the boost gauge reads at zero when the cars off.
Old Jun 2, 2007 | 10:59 PM
Polishguy33
now on top of this problem i was rotating my tires today and the lug broke when i was trying to take the lug nut off.
Old Jun 3, 2007 | 05:01 AM
Burnnout's Avatar
Burnnout
I would double check everything to make sure there is no leaks... it could be a leak from the intercooler pipes.
