A/F Ratio
Old Jun 17, 2007 | 09:25 AM
redevil's Avatar
redevil
Default A/F Ratio
So I finally installed my wideband.Took me 4 hours to install.I had to drill a hole in the dp for the bung...man that is one hard ****!!!Finally after running through 3 batteries and using an electric drill the hole was good to go.Ended up using J/B Weld, the guy at the muffler shop gave me too much bs....they get stupid sometimes.Well I let the weld dry all night and this morning I went for a drive(to work).Shifted to 3rd gear and let her rip....the wideband read a steady 10!!I got 750 injectors with return line kit...stage 0...hoping to get a good tune at Lujans this week with an e-manage.My question is, can I drive the car around for another week with those fuel ratios??will it be safe?, just to drive, no racing or speeding.
Old Jun 17, 2007 | 08:43 PM
PSI Chick's Avatar
PSI Chick
Default RE: A/F Ratio
yea it's fine. it's rich, but not damaginly so.
Old Jun 18, 2007 | 01:05 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
"No racing or speeding".............LOL!!!!!
Dusty
Old Jun 18, 2007 | 02:41 AM
PSI Chick's Avatar
PSI Chick
who races or speeds? we're all good little ones
Old Jun 18, 2007 | 12:08 PM
redevil's Avatar
redevil
lol....yeah right!!!....well stupid me tried to tighten the sensor and the J/B weld broke!!!This happened at work so lucky for me I got a welding machine here.I did the best I could while burning the **** out of me....and shut all the small leaks that were left with some more j/b weld.In 5th gear and sometimes 4th at about 2500 or 3000 the wideband goes all the way to 17 when I let off the gas..this is not good right?Should I tune the stock turbo at 20 psi?
Old Jun 18, 2007 | 07:41 PM
Aceburner's Avatar
Aceburner
I might be wrong but when u let off the gas that's supposed to happen. You have more air than fuel when u give it gas and then let off it which will run u lean. I know 17 is not a good number but when it's only when your letting off the gas like that I think it should be ok.... i think... someone want to back me up on that.
I know for a s2 the turbo can push about 20 or so psi.
Old Jun 19, 2007 | 02:19 PM
redevil's Avatar
redevil
well I guess I'll have to wait till friday for that tune and c what numbers she can push....last time it was 259 spiking 17 psi anf falling to 14, agp wga and xhaust...kinda hoping for 300
