MSD Ignition.
Old Sep 29, 2004 | 12:12 PM
71RoadRunner's Avatar
71RoadRunner
Default RE: MSD Ignition.
Yep, the MSD coil is simply a stock output coil with better windings and internal quality, but no added spark power. Most current distributorless ignitions have coil packs that put out more than enough power to get the job done and in most cases never need to be upgraded.
The MSD Super Conductor plug wires are hundreds of times better than the stock plug wires. The stock wires have over 2,000 ohms resistance on the shorter wires (#2 & 3) and the longer wires (#1 & 4) have around 3,000+ ohms of resistance and they are not even a foot long. The MSD wires are less than 50 ohms per foot of resistance, this allows hundreds of times more spark energy to reach the plugs resulting in better and more complete combustion as well as more power and far less chance of spark blow out which is a potential problem on turbocharged engines. You will notice a little difference in the idle as well as it's responsiveness. You might also notice a slight difference in it's sound too.
Old Sep 29, 2004 | 12:24 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
ORIGINAL: 71RoadRunner
I'm glad you mentioned that, I could have sworn the exhaust note got a bit louder/deeper after I installed mine, I thought maybe the PCM was self adjusting or something...
Old Sep 29, 2004 | 01:04 PM
71RoadRunner
It's fairly common, it did the same when I put them on my R/T.
Old Sep 29, 2004 | 07:28 PM
roachnigga's Avatar
roachnigga
Good point... i never really gave the stock ones a chance to tell the difference in sound. i got mines days after i bought my SRT
Old Oct 1, 2004 | 10:03 PM
uawnick's Avatar
uawnick
Now thats the answer I was looking for... Thanks man!
Old Oct 4, 2004 | 06:21 AM
71RoadRunner
Glad to be of help!
Old Oct 4, 2004 | 09:21 AM
roachnigga's Avatar
roachnigga
Why do you think i dig the Forum
ORIGINAL: uawnick
Old Oct 4, 2004 | 10:39 AM
Gump's Avatar
Gump
so do you folks thinl the new pack is worth it? i got the wires a few days after i got the car but am still wondering if the coil would be worth it?
Old Oct 5, 2004 | 08:14 AM
71RoadRunner
Only if you have all the other mods you want to do done already. If not, get the mods that will make a noticeable difference first, then you can get the MSD coil for both looks and better quality. If you want there are one or two coils out there that are higher performing and shouldn't cost much more at all. The only reason I already have the MSD coil is because I had bought it and put it on my '99 Neon R/T previously. I took it back off before I sold it so I could put it on my SRT-4 that I was getting.
