Just ordered my BOV
Old Oct 1, 2004 | 08:30 PM
  #31
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Just ordered my BOV
And with the Mopar/Borla exhaust, it's almost a perfect balance of sound.......SWEET!!!![sm=smiley20.gif]
Old Oct 2, 2004 | 01:09 AM
  #32
millenniumdna's Avatar
millenniumdna
BOV is installed. I love it. It sounds great. I have just a couple concerns, in the event i had a leak what would the car do?
Old Oct 2, 2004 | 01:31 AM
  #33
dustyloins's Avatar
dustyloins
Hall of Fame Member
Lose power.
Old Oct 2, 2004 | 01:49 AM
  #34
millenniumdna
Would you hear the leak?
Old Oct 4, 2004 | 06:24 AM
  #35
71RoadRunner's Avatar
71RoadRunner
Not likely. You would notice a loss in boost pressure, but don't forget that weather can also change how much boost you will have at any given time. If the boost is down and stays down regardless of the changes in the weather, then there might be a leak.
Old Oct 4, 2004 | 05:27 PM
  #36
dustyloins's Avatar
dustyloins
Hall of Fame Member
Prior to my air intake sensor blowing off, I could hear a whistling sound from under the hood whenever I gave it a lot of gas. I figured it was the Stage 1, but looking back, it was probably the sensor coming loose and leaking air.
Once the sensor was replaced, no more whistling.
