Boost leak
Old Jun 20, 2007 | 03:45 AM
BLKSRT4's Avatar
BLKSRT4
Default Boost leak
Ok i was at the track today. and i ran anywhere between 14.9 and 14.1 and when i got into high rpms i went from 12 psi to like 9-8psi. is there aways to fix it. and i if i get a bigger wastegate will it help with holding boost?
Old Jun 20, 2007 | 04:15 AM
PSI Chick's Avatar
PSI Chick
Default RE: Boost leak
if you're leaking fix the leak first. getting a new wga isn't going to fix a leak. do a boost leak test and tighten down the clamps and see where she sits. a 14.1 isn't THAT bad on a stock car anyway.....
Old Jun 20, 2007 | 05:51 AM
Aceburner's Avatar
Aceburner
Well do u know if you are leaking? Depending on the weather and conditions around you, your boost will change a little. A leak test will help and yes a better (but no necessarily bigger) wga will help but like PSI said only if your not leaking. Low 14's are good on the stock car. A really good driver might be able to pull a high 13. You can hold higher boost levels with better wga's but your still going to see some sort of fall in boost at some point but it shouldn't fall that low.
Old Jun 21, 2007 | 03:55 AM
BLKSRT4's Avatar
BLKSRT4
well i have intake and exhuast. and before i ran a 13.9 and it was also like 90-80 degrees out. i think im lieaking im not entirely sure
Old Jun 21, 2007 | 06:54 AM
Aceburner's Avatar
Aceburner
Well the only way to be sure is to do a test. You can buya boost leak testerfor about $25 on srtforums or I'm sure they have a how-to on here on doing one yourself. Oh and if you start messing with your boost I highly recommend a wideband. But the tester is the first and cheapest option.
Old Jun 21, 2007 | 09:26 AM
redevil's Avatar
redevil
I'll make one for you for $20..I'll even paint the sum'bitch any color you like
Old Jun 21, 2007 | 05:58 PM
BLKSRT4's Avatar
BLKSRT4
really? and how much for shipping?
Old Jun 21, 2007 | 07:59 PM
Burnnout's Avatar
Burnnout
I want one painted in black, gray, and white camo......how much for shipping ?
