HOW TO: Parking Brake Adjustment for Rear Disc Brakes
Old Jul 1, 2007 | 11:13 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default HOW TO: Parking Brake Adjustment for Rear Disc Brakes
Disclaimer: I have provided the following information and pictures out of the kindness of my heart. i assume no responsibility if you mess something up, break something, break your car, injure yourself, somehow die or otherwise f*** something up as a result of reading or attempting this.
What youll need:
- Jack
- Jack stands
- Medium sized standard screw driver
- Some good lighting (trebel light or powerful flashlight)
- Wheel chocks
- Creeper (makes life easier)
Step 1: Park on a level surface, leave the car in gear and leave the parking brake completley disengaged.
Step 2: Chock the front wheels
Step 3: Jack up the rear end of the car, supporting it on jackstands
function pointercursor(){document.body.style.cursor = "move";}function unpointercursor(){document.body.style.cursor=";}
Step 4: Scoot under the car and locate the oval shaped rubber plug covering the hole accessing the disc brake caliper adapter. Remove them and put them somewhere you wont lose them. (They are located on the inside of the brake assembly at the bottom.)
Step 5: Adjust the left (driver's side)wheel as follows:
A. Inside the access hole, there is a star wheel just above the spring. Use the screw driver, inserting it through the access hole, turn the star wheel downward until a slight drag is noticed when rotating the rear tire.
B. Rotate the star wheel upward no more than 1 or 2 clicks, backing the brake shoe off the drum just enough to allow for rotation of the wheel.
C. Reinstall the oval rubber plug.
Step 6: Adjust the right (passanger's side)wheel as follows (slightly different than the left)
A: Inside the access hole, there is a star wheel just above the spring. Use the screw driver, inserting it through the access hole, turn the star wheel upward until a slight drag is noticed when rotating the rear tire.
B. Rotate the star wheel downward no more than 1 or 2 clicks, backing the brake shoe off the drum just enough to allow for rotation of the wheel.
Step 7: With the wheels slightly off the ground (if you were using a full vehicle lift, which i obvously was not, lower the car)
Step 8: Reach into the car and fully apply the parking brake and release it two times. Fully apply the parking brake once more and leave it engaged.
Step 9: With the parking brake fully engaged, attempt to rotate each rear wheel by hand to ensure the parking brakes on each side are engaging. There should be no movement.
Step 10: Fully release the parking brake.
Step 11: Hand rotate each wheel, ensuring there is no drag caused by the parking brake shoes. (you may need to readjust the brakes as necessary, repeating steps 4 thru 11.)
Step 12: Remove the jackstands and wheel chocks.
