UEGO Sensor Placement
I searched for this and found a couple posts, but just want to be sure...I have Stage 1 PCM, and will be getting the UEGO in a week. I'm wondering where to put the new sensor---after the cat (still have stock 02 housing and cat) i/e the "second" 02 sensor, as it's no longer monitored by Stage 1? Is this correct?
ORIGINAL: dysphagia
it will still throw a code if the downstream is not heated...and placing the wideband sensor after the cat will give you false readings.
