Alcohol injection
Old Jul 18, 2007 | 11:44 AM
sverble's Avatar
sverble
Default Alcohol injection
Anyone running on your SRT4? What kit?
Old Jul 18, 2007 | 12:44 PM
redevil's Avatar
redevil
Default RE: Alcohol injection
my friend is running some Cptn.Morgan and Jack D. on his!!!!...sorry dude couldnt help it
Old Jul 18, 2007 | 04:49 PM
RIPSIGUY's Avatar
RIPSIGUY
Alky is a good mod if you get tuned for it. If you just slap it on , you will probably loose some power but it will add a little "safety" if your running silly boost.
Three systems; Snow Performance
Perrin
Aquamist
What you can do with the system is run more boost, and lean it out for more power. The alky kit just super cools your intake charge. I would recomend one with a flow monitor built in the unit if your going to tune for it. If it stopped flowing and you didn't know it, your screwed.
http://www.snowperformance.net/products.php?p_cat=192
Old Jul 19, 2007 | 10:40 AM
sverble's Avatar
sverble
I'm new to the Neon SRT4. I don't have one, but want one. So how do the Neon guys run high boost on pump gas? Is the trick mod in this crowd crazy big intercoolers and adequate fuel/injectors to supress detonation? I'm running 18 psi in my Turbo Trans am (grandnational buick turbo motor) without alcy and 25 psi on alcy and pump gas (93). I figured the acly thing would be a popular mod for the close to stock SRT-4. Turn up the boost and run alcy, maybe this isn't a popular approach with the Neon.???
Old Jul 19, 2007 | 04:38 PM
RIPSIGUY's Avatar
RIPSIGUY
I used to own an SRT4, traded it for a new Legacy GT . The Subie guys can get another 30whp with justalky and a dynotune.
As far as SRT owners running silly boost, that is just a testament to how strong that 2.4L is. They take amazing amounts of abuse.
Old Jul 20, 2007 | 12:51 AM
PSI Chick's Avatar
PSI Chick
w/i is a great mod for any car, regardless of modification level. it's even more beneficial to those that are heavily modded (big turbo especially). many srt's run w/i all the time (i do). the only thing to watch as mentioned before is that if your tune is dependant on w/i then you could run into a BIG problem if it fails. it's always suggested to tune without it, then add it afterwards.
Old Jul 20, 2007 | 01:09 AM
mopar2ya's Avatar
mopar2ya
I highly recommend the DevilsOwn kit. Im using one on my Spirit R/T and it works really well. I suggest if you run big nozzels (Im running 29 GPh at 100 psi), that you add a 3/8 feed line from the tank to the pump.
Old Jul 20, 2007 | 01:14 AM
PSI Chick's Avatar
PSI Chick
i too run a devil's own, good kit.
Old Jul 20, 2007 | 10:32 AM
RIPSIGUY's Avatar
RIPSIGUY
ORIGINAL: PSI Chick
Not to be redundant, but PSI Chick is correct in stating that if your tuned for an injection kit, you need a flow monitor. If it stops flowing you will have big problems.
Old Jul 20, 2007 | 11:17 AM
sverble's Avatar
sverble
Thanks for all the info.
