WHERE TO FIND THE SPEED SENSOR ON THE TRANNY?
Old Jul 20, 2007 | 12:52 PM
dodgesrt4man's Avatar
dodgesrt4man
Default WHERE TO FIND THE SPEED SENSOR ON THE TRANNY?
I have just bought a speed sensor for my srt4 and i was wondering if anyone could tell me where it is installed at before i tear things apart,and does anyone have a problem with theirs?
Old Jul 20, 2007 | 02:13 PM
PSI Chick's Avatar
PSI Chick
Default RE: WHERE TO FIND THE SPEED SENSOR ON THE TRANNY?
i had a problem with mine. just swapped it. if you jack up the car it's basically right in front of your face, can't really miss it.
Old Jul 20, 2007 | 08:35 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Old Jul 23, 2007 | 10:59 PM
dodgesrt4man
so you would get to it from underneath the car,because someone told me it was under the battery
Old Jul 24, 2007 | 01:00 AM
PSI Chick's Avatar
PSI Chick
yes you get it from under the car. the tranny sits under the battery, that's probably why they told you that. also contrary to the directions posted you don't need to remove the axle to get at it either. it's kinda right there once you start looking for it.
Old Jul 24, 2007 | 10:28 PM
dodgesrt4man
ok thanks,i will keep u posted because i am goin to do it soon cuz i need to put an axle in too so...
Old Jul 24, 2007 | 11:11 PM
71RoadRunner's Avatar
71RoadRunner
I can't believe they say to remove the half shaft and drive axle just to replace the sensor.[sm=huh.gif]
Old Jul 25, 2007 | 12:10 AM
PSI Chick's Avatar
PSI Chick
mopar has some pretty stupid directions a lot of the time. they tell people to drop the subframe to install s3...that creates so much unnecessary work. i think they just do it to increase book time.
Old Jul 25, 2007 | 08:40 AM
blackacr's Avatar
blackacr
Just curious, what was the issue to cause the replacement of the speed sensor??
Old Jul 25, 2007 | 12:51 PM
dodgesrt4man
i was just drivin and it started to jump and then when it rains,it dont move at all,and now it just wont move period.
