Turbo Timer.
Old Oct 18, 2004 | 02:42 PM
millenniumdna's Avatar
millenniumdna
Default RE: Turbo Timer.
Thanks for the input, how much did that run you and how hard is it to put in?
Old Oct 18, 2004 | 02:45 PM
PSI Chick's Avatar
PSI Chick
it was about $100 from exhaust depot. he supplies a harness and install video. it took about a half hour to put in...
Old Oct 18, 2004 | 02:48 PM
millenniumdna
can i ask what the install intails? Do you need to get behind the dash? Or how does it work?
Old Oct 18, 2004 | 02:51 PM
PSI Chick's Avatar
PSI Chick
you have to remove the black pieces around the steering cloumn. it's two screws that hold it in. they pop off and all the wires are right there. hector supplies the t clips and everything, and tells you which wires to tap into. it's very easy, the longest part is getting at the wires!
Old Oct 18, 2004 | 03:49 PM
millenniumdna
Doesnt sound that hard. Thanks.
Old Oct 19, 2004 | 09:39 PM
roachnigga's Avatar
roachnigga
I have an Apexi and it works great!! i usaully set it for 1 min (manually) for local drives and 3.5 min when i come out of the Autobahn... Though it does come with the auto-timer. But im not sure which wire is the O2 sensor since it has an Upper & Downstream set
Old Oct 19, 2004 | 10:58 PM
PSI Chick's Avatar
PSI Chick
you can't use the o2 sensor wire with the apexi, the volage is different in our cars. that's part of why many people don't use the apexi, most of the features don't work on our cars.
Old Oct 20, 2004 | 05:43 PM
roachnigga's Avatar
roachnigga
thnx for the info, Ma
one
