I am a newbie Please Help...
Old Aug 8, 2007 | 06:10 AM
STILL GH3TtO's Avatar
STILL GH3TtO
Default I am a newbie Please Help...
I am plannin a 50 trim kit to be installed by a shop on my 05 srt-4 and the are going to install all the fuel, turbo/excessories and tune the run about 400 whp ( not somethin i wanted to try myself)... Will the stock axels break? What issues othe than engine upgades am I gonna ned to install/ upgrageto make my whip to make it handle and hook with thekind of power I am gonna have..... and if anyone has the time/careto explain why i need what part and how its gonna benefit me I'd greatly appreciate it... I am trying to learn about my car as much as possible but i dont understand what parts i would need and why i would need them... I'll teach myself how to install them... Thank You For any input...
Old Aug 8, 2007 | 06:31 AM
redevil's Avatar
redevil
Default RE: I am a newbie Please Help...
you'll need motor mounts.Dont worry about your axels, yes they'll break, if you go to the track everyday....if you're more of a "street racer" then you should be fine, if you're planning to run on the track only then save some extra money for axles.You'll need a better clutch.Strut and Sway bars should help with handling a little bit.A better suspnsion, I suggest coilovers....dont go cheap with springs.They are not a bad choice but some springs sit your car too low and its a bitch to make slicks fit under there...it happened to me.You dont need much in your engine, it should hold 400hp easily....get a better intercooler and bov....hard pipe kit, I might be missing a few details but I'm sure some fellow owners will help you out too.Good luck with everything
Old Aug 8, 2007 | 04:43 PM
STILL GH3TtO
I have an itake, fmic, boc, and hard pipe so far
Old Aug 8, 2007 | 05:24 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
ORIGINAL: STILL GH3TtO
Swing by modernperformance.com and check out their section that explains what various mods will do for your car.......
Dusty
