Stage one and short ram mods
Old Oct 24, 2004 | 08:02 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Stage one and short ram mods
What mods do you have?
Old Oct 24, 2004 | 09:13 PM
PSI Chick's Avatar
PSI Chick
you ran an 11.61@95mph? i don't think so, that makes absolutely no sense at all.
what all do you have done
Old Oct 24, 2004 | 10:38 PM
millenniumdna's Avatar
millenniumdna
when should you perform a ecu reset?
Old Oct 25, 2004 | 12:04 AM
FastD's Avatar
FastD
ORIGINAL: PSI Chick
If you reread the post, it was a 1000' track not a quarter.. that 11.61 is a 13.8 in the quarter.
My mods are Injen Short Ram intake and spring mod.
Old Oct 25, 2004 | 12:13 AM
FastD's Avatar
FastD
ORIGINAL: millenniumdna
Basically, whenever you add a mod. But, I do it before I race also because with my spring mod I can jack the boost up and the computer won't pull it back, and I can spike 17-18psi but the computer will figure it out after a day or so and it will start pulling boost. Which that's cool cuz I don't need that much boost to drive to work anyways.
For those that don't know, a "spring mod" is a carburater spring with an adjustable hook that attaches to the wastegate and hooks to the screw under the battery. This keeps the factory WG from bleeding boost at 4psi and keeps it shut till about 15psi. It does help but your computer does it's best to stop it, that's why you reset the pcm before you race to get the full benifits of increased boost. Hope this helps.
Old Oct 25, 2004 | 12:23 AM
TurboPowered's Avatar
TurboPowered
I just got a Injen CAI and installed it yesterday should i reset my ECU?
Old Oct 25, 2004 | 12:28 AM
FastD's Avatar
FastD
I would cuz your computer still "sees" your stock air box...and you want it to forget that. Just remember your computer will always put you in check until you get the stage 1. The stock ecu is a bit of a worry wart and keeps everything level so it takes some tricks to make it all work. When I first got my intake I lost alot of boost so that's when I added the spring mod to get some of it back. Basically, just read as much as you can about this stuff www.srtforums.com has a lot of useful info.
Old Oct 25, 2004 | 07:32 PM
RIPSIGUY's Avatar
RIPSIGUY
Mount the IAT sensor in front of the intercooler, you'll see that "worry wart" pcm go wild. Esp with stage one.
I made a nice set up to get cold air up to the short ram.
I mounted the IAT where the cold air comes in, it works nice.
Old Oct 25, 2004 | 07:51 PM
FastD's Avatar
FastD
ORIGINAL: RIPSIGUY
That sounds interesting..can you descibe it alittle more..and pics would be great.
I had a Durango that I moved the IAT and it helped a lot. It was originally in the intake manifold 'seeing' only hot air so I moved it to the intake tube of the cold air kit and it seemed to advance the timing just a hair. But, it's quite possible it was my emagination but I think it helped.
Old Oct 27, 2004 | 04:36 AM
LilSparkPlug's Avatar
LilSparkPlug
ORIGINAL: FastD
ORIGINAL: RIPSIGUY
I saw his setup today and DAMN is it killer. I've never seen anything like it. After him burning through the gears everything still feels ICE COLD! Absofknloutely amazing what you can do. It looks so clean too.
I've gotta help him put the damned pictures on here so you guys can see just what he did. The way he described it, i was like wtf? Then I saw it and I was like OOOOOO!
Paul the only thing I would worry about is rain, and deep puddles, I had that problem with my 01 Stratus R/T Coupe. Used to suck up water every now and then and bubble and gurgle a bit....but it lived.
Then again I don't even think your car knows what bad weather is!!!
