a small leak
Old Aug 20, 2007 | 06:01 PM
vaughn35's Avatar
vaughn35
Default a small leak
hey i have a small leak around this rubber cover on the tranny.....what is this cover??? thanks
Old Aug 20, 2007 | 06:02 PM
vaughn35's Avatar
vaughn35
Default RE: a small leak
[IMG]local://upfiles/62988/AC17A1BD06F248CDB1206768D50A25A9.jpg[/IMG]
Old Aug 20, 2007 | 07:01 PM
PSI Chick's Avatar
PSI Chick
that's your slave cylinder. you should get that looked at.
Old Aug 20, 2007 | 07:05 PM
vaughn35's Avatar
vaughn35
hey you mean the cylinder unit is under that cover??.thanks for the help Amy
Old Aug 21, 2007 | 12:27 AM
PSI Chick's Avatar
PSI Chick
yea it is. that's not something you want leaking, it could cause shifting issues and possibly tranny problems if it goes bad. it should be under warranty, take it in and have them look at it. better safe then sorry, especially with transmissions lol
Old Aug 21, 2007 | 05:32 PM
vaughn35's Avatar
vaughn35
ok thanks
Old Aug 24, 2007 | 05:56 PM
vaughn35's Avatar
vaughn35
HEY is the clutch slave cylinder something i could put in myself......reason being..i cant leave my car at the dealer..something i need to fix on saturday and sunday........i got a friend that said he would help...he said the hard part is bleeding it
Old Aug 24, 2007 | 05:59 PM
tyler819's Avatar
tyler819
i dont think u can bleed it, it is really easy to change if u no how to do it, ive taken out and put back mine many times
Old Aug 24, 2007 | 06:08 PM
vaughn35's Avatar
vaughn35
ok thanks i just called the local dealer and he said 143 dollars for the part???....i seen one on ebay for 42 dollars
yes i found the directions online on how to bleed it....seems complicated though thanks
Old Aug 24, 2007 | 06:10 PM
tyler819's Avatar
tyler819
dont u just pump the clutch a bunch of times and push the rod on the slave cylinder in a bunch of times
