stage 2
Old Aug 21, 2007 | 12:00 AM
davanzojga's Avatar
davanzojga
Default stage 2
what do you need to do a stage 2
Old Aug 21, 2007 | 04:19 PM
JLHILL's Avatar
JLHILL
Default RE: stage 2
What do you mean? What do you need to do a s2? You need to find someone to buy it from, I guess.
Try Speedandpowerdevelopment.com
Old Aug 22, 2007 | 06:43 PM
blue_srt4's Avatar
blue_srt4
Default RE: stage 2
or if u dont want the turbo toys, u can also buy it used.
Old Aug 23, 2007 | 12:34 AM
davanzojga's Avatar
davanzojga
Default RE: stage 2
i already have some parts like the stage2 ecu waste gate bigger inter cooler turbo back exhaust so what i mean is what other parts would ineed
Old Aug 23, 2007 | 10:44 AM
Kapitald's Avatar
Kapitald
Default RE: stage 2
if you go to mopar . com they will tell you exactly whats in all the staged upgrade kits......your bolt-ons you listed arent in any of them....in fact, even the stage 3 still uses the stock intercooler....
but stage 2 has the stage 2 pcm....a 3.0 bar tip sensor...a 3.0 bar map sensor....bigger injectors to name a few....
heres a link...
https://dodgeforum.com/m_265244/tm.htm
http://www.mopar.com/srt_stage_2.htm
Old Aug 23, 2007 | 11:01 PM
blue_srt4's Avatar
blue_srt4
Default RE: stage 2
well to complete your stage2, u'll need the sensors and the injectors.
Old Aug 28, 2007 | 01:32 AM
davanzojga's Avatar
davanzojga
Default RE: stage 2
thanks helped alot
