ECU REFLASH
Old Aug 29, 2007 | 01:36 PM
BLKSRT4's Avatar
BLKSRT4
Default ECU REFLASH
i went to the dodge dealer today and they were saying the cant reflash my stage1 ecu. and then it has to be in the car to do. what is up with that. is there a way i can order a reflash so i can do it myself. and if so where at?
Old Aug 29, 2007 | 01:47 PM
SRT_YA's Avatar
SRT_YA
Default RE: ECU REFLASH
order a reflash? ummm... no, not that I've ever heard of... because you'd be ordering code, which in turn you'd have to install on the ECU somehow (hence the flash)
do they use the ODBII port for a flash? or is there a breakout on the harness for it? if so, I could def. see why they'd need it in the car!
Old Aug 29, 2007 | 01:53 PM
BLKSRT4's Avatar
BLKSRT4
but the car wont run with in unless they install it when they get it there. but how can you reflash a stage one will it get rid of the vin and everything?
Old Aug 29, 2007 | 02:17 PM
PSI Chick's Avatar
PSI Chick
you can send it to flightsystems. the info is in the mpsc section on srtforums.
Old Aug 29, 2007 | 06:57 PM
BLKSRT4's Avatar
BLKSRT4
MPSC? but can dodge do it though?
Old Aug 29, 2007 | 07:45 PM
Burnnout's Avatar
Burnnout
Moparsupercenter .... dodge can do itbut teaching them how to is a big pain in the ***.... search the topic on srtforums and you'll see.
Old Aug 29, 2007 | 09:16 PM
BLKSRT4's Avatar
BLKSRT4
oh great trying to teach them about turbos is hard their idiots
