msd ignition
Old Aug 30, 2007 | 02:53 AM
dodgesrt4man's Avatar
dodgesrt4man
Default msd ignition
i am lookin at the whole msd ignition setup for my 2005 srt4.i was wonderin if anyone has it and can tell me info bout ti or knows about it.how was it to install and how does it work over all?
Old Aug 30, 2007 | 05:46 AM
talisman's Avatar
talisman
Default RE: msd ignition
I think the overwhelming majority of people in here will tell you to save your money. Put a good set of plugs and wires on with the stock coil and you'll be good. Don't buy MSD's coil.
Old Aug 30, 2007 | 07:15 AM
MAssSrTdriven's Avatar
MAssSrTdriven
i bought the msd coil and wire set off ebay rather cheap. i put the coil on after everyone says its junk but my runs runs a hell of a lot better now, however i know i needed new wires because my #3 wire had a small leak. so im sure just the fact changing the wires is the reason it runs better as far as the coil idk its working fine lol
Old Aug 30, 2007 | 08:54 AM
PSI Chick's Avatar
PSI Chick
everyone says its junk not because it doesn't work well, it certainly does, the problem is that it only works well for about 6-8 months and then it leaves you stranded on the side of the road.
Old Aug 30, 2007 | 11:45 PM
dodgesrt4man
ok,thats the coil,what bout the ignition system on modernperformance for like 400
Old Aug 31, 2007 | 01:24 AM
PSI Chick's Avatar
PSI Chick
that's a dis-2. not sure why they bother calling it an ignition system, the only thing that works on our cars is the 2-step. and unless you're at the track a lot it's not worth it.
Old Aug 31, 2007 | 02:23 AM
dodgesrt4man
so how would i be able to get a 2 step or launch control without buyin the whole thing,i would love to have it on my car for when i race
Old Aug 31, 2007 | 09:09 AM
PSI Chick's Avatar
PSI Chick
you don't. it's a box, you can't buy part of it. get either the launch control or the 2-step, those are your only options. but again, unless you race a lot it's not worth the money imo/ime
Old Mar 15, 2009 | 08:44 PM
streetbikr600's Avatar
streetbikr600
my buddy is trying to sell my a msd 6btm box with a boos t retard and advance has any one put this on there neon or heard things about it for the price it sounds good
Old Mar 18, 2009 | 11:53 AM
mldsrt4's Avatar
mldsrt4
ive been running msd coil and wires with denso irridiums plugs for about 2 years put about 25 k on them with not problems at all.....cant argue with that
