BAD WASTEGATE
Old Sep 2, 2007 | 11:13 PM
PSI Chick's Avatar
PSI Chick
Default RE: BAD WASTEGATE
set the wga to about 12psi then adjust with the boost controller to get your desired psi (no more than 16 psi or so on the stock fuel)
Old Sep 5, 2007 | 03:00 AM
dodgesrt4man's Avatar
dodgesrt4man
should i hold 16 or spoke to 16
Old Sep 5, 2007 | 09:01 AM
PSI Chick's Avatar
PSI Chick
you can hold 16, spiking 18 or so.
Old Sep 6, 2007 | 03:46 AM
dodgesrt4man
ok thanks,one more question,what do u set the wga to and then what do u do with the bc.also is the slowboyracing wga any good that u know of?
