Next Step??
Old Sep 6, 2007 | 02:23 PM
PSI Chick's Avatar
PSI Chick
Default RE: Next Step??
what?
Old Sep 6, 2007 | 02:51 PM
MEandmySRT's Avatar
MEandmySRT
ORIGINAL: PSI Chick
what?
i was thinking the same thing, because i thought the stock turbo/manifold took a different o2 housing than the s3 turbo/manifold took.
quoting from Maxxfab site:
"These housings have the same features as the OEM replacement housings decribed above, but have the pentastar shaped Stage 3 flange needed for installation to the Stage 3 exhaust manifold.
The inlet to the O2 housing has been expanded to approx 3.75inches in diameter to take full advantage of the exhaust opening in the Stage 3 exhaust manifold. The exit end of the O2 housing is 3 inch in diameter. This allows any aftermarket exhaust to bolt right up the the MAXX Fab Satge 3 O2 housing."
Old Sep 6, 2007 | 03:16 PM
PSI Chick's Avatar
PSI Chick
yea the stocker is a 4 bolt, the s3 is a 5 bolt. i just have no idea what he said lol
