mopar stage 3 uprgade
Old Sep 22, 2007 | 01:04 PM
hub3rt's Avatar
hub3rt
Default mopar stage 3 uprgade
i have a stock engine andi was thinking about adjusting my boost to 20psi. Is there gonna be a chance that im gonna blow up my engine?
Old Sep 24, 2007 | 11:22 AM
Burnnout's Avatar
Burnnout
Default RE: mopar stage 3 uprgade
Assuming you have stage 3 ... then no 20psi is fine. By stock engine I'm guessing stock internals.... so what are your mods ?
Old Oct 7, 2007 | 09:12 PM
blue_srt4's Avatar
blue_srt4
shouldn't this be in the drivetrain section?
Old Oct 10, 2007 | 05:02 PM
srt4ACRboy's Avatar
srt4ACRboy
yes it should be, but if u have a stage 3, 20psi is fine but if you dont, 16psi at the max
Old Nov 3, 2007 | 06:22 PM
hub3rt's Avatar
hub3rt
yah all my internals are stock... alright, thanks guys!
Old Nov 24, 2007 | 02:38 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
ORIGINAL: blue_srt4
yes, it should have been. better late than never
and sorry bout the edit on your post, hit edit instead of quote. still getting used to the extra buttons
Old Nov 24, 2007 | 01:37 PM
PSI Chick's Avatar
PSI Chick
it's very dangerous to "assume" anything. if you're going to play with boost put a wideband in.
Old Mar 26, 2008 | 03:03 AM
neonbob22's Avatar
neonbob22
maybe you can help me out here psichick already posted "I need injectors" but what would be the best size injectors for a full satge 3 system i plan on pulling the motor and building it all
Old Mar 26, 2008 | 09:54 AM
PSI Chick's Avatar
PSI Chick
you're going to build the motor and only use a s3 turbo? ok well you can go as small as the s2/s3 680's or as large as 825's (assuming you're using a fuel controller)
