coolant ?
Old Sep 22, 2007 | 05:15 PM
05SRTStage3's Avatar
05SRTStage3
Default coolant ?
Ok I went to the local dealership to pick up some more coolant. Because my level was low and I have noticed that I am running a little hotter than normal. Well I have a Stage 3 if that matters. But the lady gave me the coolant and I noticed it was orange. I have green in my car. About a year ago I had a HUGE issue with my car. The dealership screwed it up then refused to fix it. And voided my warranty. So to make a long story short I sued them and I WON. But anymways when I had the work done at a local shop I am sure that is when I get the green. The dealership mechanics said that I need to flush the green out ASAP. I know that I CANNOT mix green and orange. But I was wondering if anyone had any thoughts.
Old Sep 22, 2007 | 05:49 PM
PSI Chick's Avatar
PSI Chick
Default RE: coolant ?
you need to get rid of the green stuff and put in the red/orange stuff
Old Sep 22, 2007 | 06:32 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Sounds like you need to avoid that "local shop" bigtime.........
Dusty
Old Sep 24, 2007 | 08:31 AM
Burnnout's Avatar
Burnnout
Does anyone know the difference between the different coolant types ?
Old Sep 24, 2007 | 09:20 AM
Birdman's Avatar
Birdman
The difference between the two colors is that orange antifreeze contains a different type of corrosion inhibitor that has a much longer service life than the silicates, phosphates and borates in the green antifreeze. Orange antifreeze contains organic acids that offer greater protection from corrosion.
GM / 1994 or Older/ Green
GM /1995 or Newer/ Orange
Chrysler / 2001 or Older/Green
Chrysler / 2002 or Newer / Orange
Ford / 2001 or Older / Green
Ford / 2002 or Newer / Yellow
I found this info at http://bioengr.ag.utk.edu/Extension/...es/engcool.htm,http://lilmikeswackyworldofautomotiv...1_archive.html, and http://www.peakantifreeze.com/tech/tech_a.html.
Old Sep 24, 2007 | 11:16 AM
Burnnout's Avatar
Burnnout
Nice info.
Old Sep 24, 2007 | 04:29 PM
srt4ever's Avatar
srt4ever
^^^^ Agreed!
Old Sep 24, 2007 | 04:37 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Ditto. And you can do like I did, read the back label of the bottle of Prestone......
Dusty
Old Sep 24, 2007 | 04:41 PM
Burnnout's Avatar
Burnnout
What's funny about the back of Zerex bottles, is it says Nissan should take Dexcool..... which is incorrect.
Old Sep 24, 2007 | 06:05 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Attention Nissan Owners: Contact your lawyers!!!
Dusty
