Question about over boost code
Old Oct 2, 2007 | 07:38 PM
Moparmatt440's Avatar
Moparmatt440
Default Question about over boost code
I keep getting the stupied over boost code, the car has a stock ecu, but has a turbo xs manuel boost controller and turbo xs bov, agp waste gate,and a K&N typhoon intake. Im getting 15 psi right now but I turned it down and I still get the same code. Will I keep getting this code until I upgrade to a stage ecu?
Old Oct 3, 2007 | 12:36 AM
PSI Chick's Avatar
PSI Chick
Default RE: Question about over boost code
did you ever clear the code or you just let it sit there? codes don't disappear unless they're cleared, so if youleft the code in there it will pop up again. a stage ecu is the easiest way to get rid of the overboost issue.
Old Oct 3, 2007 | 07:15 PM
Moparmatt440
I have cleared the code, just by disconnectiong the negitive side of the battery, but a stays off fora bit then it just came back on today when I was going back to work and I only hit maybe 10 psi.
