TURBO SURGE????
Old Oct 4, 2007 | 03:19 PM
BOISEBLUE's Avatar
BOISEBLUE
Default TURBO SURGE????
ive been researching the web and i belive im experiencing turbo surge. im not 100% on this but if so, does anyone have a f!@#$%* cure im goin crazy, i dont want my turbo crapping out on me.
Old Oct 4, 2007 | 03:28 PM
Burnnout's Avatar
Burnnout
Default RE: TURBO SURGE????
.....What are your symptoms ?
Old Oct 4, 2007 | 05:45 PM
BOISEBLUE's Avatar
BOISEBLUE
fluttering at low load boost.
Old Oct 5, 2007 | 09:35 AM
PSI Chick's Avatar
PSI Chick
i'm going to assume that you have a wga/mbc on the stock turbo? welcome to part throttle overboost. you can't fix it. learn to live with it. it's either 20% or 100% throttle. you need to relearn how to drive your car.
Old Oct 5, 2007 | 10:30 AM
BOISEBLUE's Avatar
BOISEBLUE
i dont have a stock turbo. does that change anything?
Old Oct 5, 2007 | 07:38 PM
PSI Chick's Avatar
PSI Chick
what turbo do you have and what is your wga and mbc set at
Old Oct 6, 2007 | 11:10 AM
BOISEBLUE's Avatar
BOISEBLUE
i believe its a 50 trim but i could be wrong.i dont know what my wga and mbc are set at?
Old Oct 6, 2007 | 12:04 PM
Burnnout's Avatar
Burnnout
What you are hearing is either noise from your intake....... or the normal noise a HKS BOV will make at low boost. IMO
Edit: Spelling
Old Oct 6, 2007 | 01:54 PM
PSI Chick's Avatar
PSI Chick
you don't know what turbo you have or what your wga or mbc is set at?
Old Oct 7, 2007 | 12:27 AM
blackacr's Avatar
blackacr
Mine does this too.... stock turbo, stock WGA, and no boost controller, also stock stage 0 ECU. I do have a BOV, (compressor mounted like forge, hooked up w/ the pink line) and an AEM Short intake. The only clean release I get is at high boost. I talked to a fellow SRT 4 owner the other day and his friend said "dude that's a lot of compressor surge.. that sounds bad" As far as I know this is normal on our cars... Is this true??
