Turbo cutting out??
Old Oct 12, 2007 | 08:25 AM
Burnnout's Avatar
Burnnout
Default RE: Turbo cutting out??
You need tocap the pink line and T into the line coming off of the throttle body.
Old Oct 14, 2007 | 01:00 AM
blackacr's Avatar
blackacr
Turns out the spring was too hard, I swapped out the spring for a lighter one and it works a lot better. nice and smooth. I thought about doing that too (putting a "T" on the TB vac line.) thanks for the input.
Old Oct 15, 2007 | 09:27 AM
Burnnout's Avatar
Burnnout
Youshould reallychange it up ... the pink line doesn't see enough boost to operate your BoV properly.
Old Oct 16, 2007 | 12:49 AM
PSI Chick's Avatar
PSI Chick
or just get a real bov [:@]
Old Nov 3, 2007 | 07:17 PM
daporkchop03's Avatar
daporkchop03
hello i have a stock srt-4.. nd i juss put a 3 inch tsudo downpipe along with a borla exhuast.. nothing else.. about 4 days later the car would like give me problems everytime the boost kicks in high or whenver i step the full gas pedal down at any rpm and it will not go it wil liek boch.. check engine is on for p0420 and p0300. i changed the spark plugs and wires and still no improvement can any please tell me wats wrong..
