Boost Gauges
Old Nov 10, 2004 | 06:21 PM
NeonOrngBlast's Avatar
NeonOrngBlast
Default Boost Gauges
In normal driving is the boost gauges supposed to be at neg. 20 psi? And yes i am a noob.
Old Nov 10, 2004 | 06:36 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: Boost Gauges
Depends on what gear your in and your RPMS. Under normal driving I'm usually in VAC, unless I drive like Paul then I'm boosting like no other (LOL). The car doesn't boost all the time, obviously, so running under VAC is best if you wanna save gas and such. But under normal driving, VAC is normal. Like I said depends on your speed/rpms how much VAC the gauge reads, but normal driving = VAC.
Old Nov 10, 2004 | 06:52 PM
roachnigga's Avatar
roachnigga
AT start up (idle) its normal for the boost guage to be at -20. Once you punch it, itll go from vac to press. Also, even on "normal" driving condition its common to be at the setting once you have the speed you required
Peace
