is this normal???
Old Nov 14, 2004 | 05:54 PM
badsrt4's Avatar
badsrt4
Default is this normal???
ok guys, friday as i was comming out of school parking lot, i turned to the main street and had to speed pass some body, so i punched in second gear and got 20 psi of boost, the turbo sounded loud so i figured it was a boost leak, yesterday, i lifted the car a looked at the clamps holding the pressure pipe, and found out they were all loose, so i tied them up, took it for a testr drive and i did the same thing, first gear almost 15 psi, 2nd and on 20psi, and by the way, it is kind of cool down here in tx, i unplugd the battery all night to reprogram the computer and wanted to take it for a test drive but its raining. Is there any other clamps i should tied up??? i have S2 and a BOV...
Old Nov 14, 2004 | 07:43 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: is this normal???
When I punched mine in 2nd, the intake air sensor popped out.....it's right under the airbox on the air intake tube....
Old Nov 14, 2004 | 08:01 PM
Bruins013's Avatar
Bruins013
the clamp behind intake pipe on the turbo, u need a really long extension...
Old Nov 14, 2004 | 08:53 PM
badsrt4's Avatar
badsrt4
ORIGINAL: dustyloins
i took the air box to check all the clamps, i only unplugged two hoses, the only sensor i noticed was the one on the little tube that goes to the fender its this the one u talking about????
Old Nov 15, 2004 | 02:37 AM
Gump's Avatar
Gump
arnt you suppost to get 20 psi with stage 2?
Old Nov 15, 2004 | 02:55 AM
LilSparkPlug's Avatar
LilSparkPlug
If not close to it I thought it was around 18-20psi myself. Unsure of Spike or Hold though.
Old Nov 15, 2004 | 02:56 AM
Gump's Avatar
Gump
sexy what mods did you have on yours?
Old Nov 15, 2004 | 03:00 AM
LilSparkPlug
Engine-wise none. I only had 4678 on it when I crashed. But for some unknown reason mine was fast as hell from the factory...not too sure why. You can ask RIPSIGUY too, hes said hes never driven a stock one as fast as mine. LOL Stock for stock mine was faster than HIS! And he drives better than me!
Old Nov 15, 2004 | 03:02 AM
badsrt4's Avatar
badsrt4
ORIGINAL: Gump
yes but not in the cold weather... plus i've never hit 20 psi in second gear before, and 3rd it actually passed the 20 psi mark, i was also thinking that my subs could have messed up my gauge, cause it rattles whenever my speakers bump.
Old Nov 15, 2004 | 03:06 AM
LilSparkPlug
Get a digital gauge. Once you get to Stage 2, the stock gauge gets very very confused! Digi-gauges are a helluva lot more accurate too
