Gauge ?
Old Nov 15, 2004 | 04:19 AM
Gump's Avatar
Gump
Default Gauge ?
Does anyone know what gauge will fit if any in the stock gauge holder?
Old Nov 15, 2004 | 05:52 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: Gauge ?
Boost Gauge?
Old Nov 15, 2004 | 06:15 AM
Gump's Avatar
Gump
Default RE: Gauge ?
yeah....
Old Nov 15, 2004 | 06:24 AM
LilSparkPlug
Default RE: Gauge ?
Any 2 1/16th" boost gauge should fit. And/or 52mm
Old Nov 15, 2004 | 06:27 AM
Gump's Avatar
Gump
Default RE: Gauge ?
should... but has anyone done it?
Old Nov 15, 2004 | 10:55 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Gauge ?
Any 2 1/16" gauge will fit, the factory gauge is an Auto Meter Pro Comp Ultra Lite 2 1/16" boost gauge, so they'll fit as long as they are the right size. The "other" forum has directions on how to make those pods and install them.
Old Nov 15, 2004 | 12:37 PM
RIPSIGUY's Avatar
RIPSIGUY
Default RE: Gauge ?
I want an oil temp gauge.......right next to the boost gauge. The damn A pillars are wide enough with oput putting
pods there. Pic will come when done. Pro Comp makes an ultralite to match the boost gauge.
Old Nov 15, 2004 | 01:03 PM
PSI Chick's Avatar
PSI Chick
Default RE: Gauge ?
i have a 30psi boost gauge in the stock pod. fits just fine. i also have another pod that i was going to install another gauge in, but i decided to get the dual pod a pillar instead. i spoke to dale about how to install the pod, so i have a good idea about it, just haven't done it because i went a different route. if you do it and run into problems, let me know and i'll try to help.....
Old Nov 15, 2004 | 02:09 PM
LilSparkPlug
Default RE: Gauge ?
ORIGINAL: RIPSIGUY
Theres definitely enough room for one in that useless waste of space up there. Pix will come huh?? Lol if you can get them on the comp they will! I'm just teasing you hunn
Old Nov 16, 2004 | 10:20 AM
Tipop's Avatar
Tipop
Default RE: Gauge ?
You can always lay coins up there and when taking a sharp corner they are hillarious weapons as they fly off and hit the passanger in the forehead. [&:]
