need help with wastegate
Old Nov 7, 2007 | 09:54 PM
faststage02005's Avatar
faststage02005
Default need help with wastegate
my friend has a problem with his agpwastegate...he tried turning up his boost on the manual boost controller..but he couldnt ,no matter how high he turned up the boost on the controller or the wastegate arm it would still spike at17psi....he disconnected the negative on the battery to reset it but it would still not change..he ran a line from the back of the turbo directly to the wastegate too, but no change...any help would be appreciated...thank you
Old Nov 7, 2007 | 11:57 PM
PSI Chick's Avatar
PSI Chick
Default RE: need help with wastegate
what's the wga set at?
Old Nov 8, 2007 | 08:34 AM
faststage02005
well it spikes at 17 and drops to 15...
Old Nov 8, 2007 | 09:17 AM
Burnnout's Avatar
Burnnout
What are his other mods ? .....
Old Nov 8, 2007 | 04:52 PM
faststage02005
agp intercooler.
agp cold air intake
hks bov
agp wastegate
turbo xs mbc
Old Nov 8, 2007 | 05:09 PM
Burnnout's Avatar
Burnnout
You don'thave the fuel to be boosting more than that.
Old Nov 8, 2007 | 05:12 PM
faststage02005
yeah but why is it doing that??
Old Nov 9, 2007 | 01:04 AM
PSI Chick's Avatar
PSI Chick
because you're running only off the wga. there's only a 10lb spring in there, he's lucky to be able to hold even that. set the wga at 12psi (set it with the mbc off) and then turn up the boost from there.
Old Nov 9, 2007 | 08:45 AM
faststage02005
well from mine i just tune it from the wastegate....but he cant even do that or even with the boost controller..no matter how much he turns it up the boost still stays the same.
Old Nov 9, 2007 | 09:50 AM
PSI Chick's Avatar
PSI Chick
you don't tune with a wga. you tune with a bc. set the wga at 12 and tune with the mbc. if the boost won't change something is hooked up wrong.
