ngk
Old Nov 16, 2004 | 11:43 PM
gilles's Avatar
gilles
Default ngk
i just bought 4 ngk iridium
at what gap i should keep those?
thanks.
Old Nov 16, 2004 | 11:45 PM
Bruins013's Avatar
Bruins013
Default RE: ngk
ORIGINAL: gilles
thanks.
my reg NGKs r gapped at .040
Old Nov 16, 2004 | 11:51 PM
gilles's Avatar
gilles
Default RE: ngk
i read in some threads with stage 1 you need to keep you gap at 35, 40
the stock sparkplugs are gap at 50
Old Nov 17, 2004 | 12:00 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: ngk
I go with .045 on my stock plugs (with Stage 1)...zero problems in the 6 months I've had it....
Old Nov 17, 2004 | 01:11 AM
PSI Chick's Avatar
PSI Chick
Default RE: ngk
what are your mods? the more boost you run the lower gap you should go. i'm running .035 right now, and will probably lower it a little soon. bone stock .045 is good, .040 for basic bolt on stuff (s1, etc.).
Old Nov 17, 2004 | 01:38 AM
gilles's Avatar
gilles
Default RE: ngk
s1,h/fcat+borla,msd wires,forge wgt
Old Nov 17, 2004 | 02:11 AM
PSI Chick's Avatar
PSI Chick
Default RE: ngk
.035 or .040 would probably be best. try both and see which one the car feels better with and go with that.
Old Nov 17, 2004 | 07:20 PM
roachnigga's Avatar
roachnigga
Default RE: ngk
I gapped mines to .040 with my stage 2. plugs still looked good after a month of hard boosting
ORIGINAL: gilles
thanks.
Old Nov 19, 2004 | 09:47 AM
SRT_YA's Avatar
SRT_YA
Default RE: ngk
this is a bit off topic... but...
I HAVE A JOB INTERVIEW WITH NGK!!!!!!!!! for a sales/application engineering position!!!!! I am so excited!!!!!
Old Nov 19, 2004 | 11:50 AM
roachnigga's Avatar
roachnigga
Default RE: ngk
good-luck
