satge 2 or fuel mods
Old Nov 10, 2007 | 10:15 AM
faststage02005's Avatar
faststage02005
Default satge 2 or fuel mods
whats a better route to go with..
stage 2 injectors with dtec or mopar stage 2....???
i wanna spike like 20 psi dropping to 18psi...
Old Nov 10, 2007 | 12:45 PM
PSI Chick's Avatar
PSI Chick
Default RE: satge 2 or fuel mods
either one will do it
Old Nov 10, 2007 | 12:59 PM
faststage02005
psi chick: is it true that stage 2 sucks from a roll???
Old Nov 10, 2007 | 05:32 PM
PSI Chick's Avatar
PSI Chick
basically yea. it's a stage kit that's meant for the track, and does best from a true launch. it's a lot better if you tune it with a dtec or something, as much of the problem is that it runs so rich that it can just kill the powerband.
Old Nov 10, 2007 | 05:57 PM
faststage02005
so i just need the injectors and dtec?? thats it....n street tune it
Old Nov 11, 2007 | 12:29 PM
PSI Chick's Avatar
PSI Chick
you'll need a return line also so you can adjust static fuel pressure, running s2 injectors you want your pressure around 52 or so, not the stock 58. a fuel pump is a good idea as well......
Old Nov 11, 2007 | 08:08 PM
faststage02005
you think i can hit a 12.5 on slicks.?
Old Nov 12, 2007 | 09:28 AM
PSI Chick's Avatar
PSI Chick
what other mods
Old Nov 12, 2007 | 10:31 AM
faststage02005
intercooler
mopar intake
wastegate holding 19psi
fuel pump
stage 2 injectors
dtec
turbo back exhaust
mm
slicks
ARE 750CC INJECTORS BETTER THAN STAGE 2 INJECTORS?
Old Nov 12, 2007 | 11:15 AM
Burnnout's Avatar
Burnnout
Better for your current setup ? ... no. Stage 2 injectors are plenty big.
