wideness of tiredd!!!
Old Nov 18, 2007 | 04:58 PM
daporkchop03's Avatar
daporkchop03
Default wideness of tiredd!!!
right now i have 215/40/r17 bc i got all ma tires slashed wit the stock ones. but neways i was thinkin of liek 235's by 40's or 45's mwats best for it thatll it make look nice fron the back
Old Nov 19, 2007 | 12:28 AM
PSI Chick's Avatar
PSI Chick
Default RE: wideness of tiredd!!!
a 215 is as wide as you can go on the stock rim, and even that's pushing it. if you get a 7" rim you can go 225 on stock suspension, and depending on the rim 235. 245's are pushing it and usually rub.
you shouldn't be buying tires for the "stance" either. they are an important part of the car, not just for looks.
Old Nov 19, 2007 | 04:44 PM
srt4ACRboy's Avatar
srt4ACRboy
i have 225/45z/16 on mine
edit; woops you have 17's [&:]
Old Nov 21, 2007 | 02:24 AM
Pressurecooker's Avatar
Pressurecooker
I have 225-55-16's on mine on aftermarket rims that are 16x7. No rubs even when lowered. Fuzion ZRI tire works excellent and is priced right.
[IMG]local://upfiles/15665/5BADFA88D0044DB1822923A4F5041EF4.jpg[/IMG]
Old Dec 16, 2007 | 02:40 PM
srtratblock's Avatar
srtratblock
Can you put 245/40/17 with 8' wheel with 35mm setback on srt4 without clearance issues. srt forumms under wheel and tire thread says you can. Just wondering if anybody has tried this. Oh, this is with stock suspention, not lowered.
Old Dec 16, 2007 | 04:27 PM
PSI Chick's Avatar
PSI Chick
not with stock suspension
Old Dec 16, 2007 | 04:53 PM
srtratblock
Thanks for the info.
Old Dec 16, 2007 | 10:17 PM
STILL GH3TtO's Avatar
STILL GH3TtO
I have k sport kontrol coilovers.... how wide can i go? 8 or 8 1/2. i am still riding stock and they dont hook.... what a good rubber??
