new stage 2 ecu
Old Nov 25, 2007 | 04:05 PM
the beast14's Avatar
the beast14
Default new stage 2 ecu
Ok I just bought the stage 2 ecu but I need to reflash it to my vin # but I took it to dodge they said they couldn't do it cuz its illegal here in california so I need help where can I send it or take it to get it reflashed
Old Nov 25, 2007 | 04:41 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: new stage 2 ecu
Flight Systems can do it for you......
Flight Systems
33820 Riviera Dr
Fraser, MI 48026
Attn: Stephanie/Reprogram
Dusty
Old Nov 25, 2007 | 11:51 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
its illegal??? wtf?
Old Nov 26, 2007 | 01:53 AM
the beast14
do i just send it to that address or what is there a website. and yea its illegal here in california lol
Old Nov 26, 2007 | 05:24 AM
flamingpinhead
Section Moderator
wow, not to offend but thats pretty dumb.
this was posted a long time ago:
Reflashing Your PCM
I cannot reflash stock units!! I have been helping out and paying for shipping back to you, but if I receive anymore stock then you will have to pay for the shipping back to you without the vin reflash being done. I'm sorry but I dont know how many times I can tell everyone that I CANNOT reflash stock modules.
Hello,
My name is Stephanie and I am from Flight Systems, the company that supplies you with your turbo kits. If you have bought a used stage kit and need your vin number reflashed into it you can send your pcm to me and I can reflash it for you. I can NOT reflash stock pcm's. As you should know, if you do not reflash the module and try to install the pcm in your vehicle without changing the vin, your vehicle will not start. The charge for this will be $30 plus s&h plus the COD charge. I can either ship it back to you overnight air, which is expensive or ground which will only cost $4-5 more on top of the $30 plus the $7 charge for COD. The cost for everything will be around $43, which will come COD (collect on delivery). Everything will be sent back using the carrier UPS, no exceptions. When the driver drops your pcm off you must give him a check or money order made out to Flight Systems, for the exact amount. Once I ship your pcm out, I can send you a pm with your tracking number and total COD amount. The new address is:
Flight Systems
33820 Riviera Dr.
Fraser, MI 48026
Please make sure to put inside the box your vin number, return address, a telephone number I can reach you at in case of any problems,your name on the forums, and how you would like it sent back to you; ground or overnight. Your mileage is not needed because that is not programmed into the modules. Please make sure the pcm is packaged properly, any damage that happens on delivery to me is not my respondsibility. Let me know when you are sending it out to me by pm so I know when it should arrive. I will ship it back out to you 1-2 days after I receive the kit. If you have any questions, you can pm me as well. Have a great day!!
Stephanie
Flight Systems
Parts Department[/align]
search around, they may have a phone# as well. they used to have an account with one of the 'other forums' so you could just pm stephanie as well.
Old Nov 26, 2007 | 08:02 AM
Burnnout's Avatar
Burnnout
You can also call mopersupercenter.....they will give you the number.
Old Nov 26, 2007 | 09:32 AM
PSI Chick's Avatar
PSI Chick
it's not illegal in california, they just didn't know how to do it and made up an excuse.
Old Nov 26, 2007 | 11:12 AM
the beast14
Thanks guys. And it is illegal it won't pass smog
Old Nov 26, 2007 | 11:16 AM
flamingpinhead
Section Moderator
^as for smog test, couldnt you could keep your S0 PCM around the house. so when it comes up time for your inspection, throw the S0 back on?
Old Nov 26, 2007 | 12:57 PM
Burnnout's Avatar
Burnnout
Are smog tests done at idle ?
