Boost Gauge Problems
Old Nov 27, 2007 | 04:16 PM
dparsons06's Avatar
dparsons06
Default Boost Gauge Problems
Ok i just bought my car last friday and i noticed when i shut my car off the boost gauge only goes to 10, isnt it supposed to go back to 0 when the car is off?
Old Nov 27, 2007 | 05:32 PM
PSI Chick's Avatar
PSI Chick
Default RE: Boost Gauge Problems
yes. you need a new boost gauge.
Old Nov 27, 2007 | 05:45 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
if you got any kind of warranty with the car, have them replace the boost gauge. otherwise you might as well just get an aftermarket gauge that will be more reliable. the stock gauges are prone to failure
Old Nov 27, 2007 | 06:40 PM
dparsons06's Avatar
dparsons06
Also it never moves to the Pressure the gauge just stays between 10 & 20 on the Vacumn side, just want to make sure its only an issue with the gauge and nothing else
Old Nov 27, 2007 | 06:46 PM
dparsons06's Avatar
dparsons06
Differnt topic but while im on here, when i shut the car off it kind of shakes is that normal?
Old Nov 28, 2007 | 12:37 PM
srt4ACRboy's Avatar
srt4ACRboy
does it shake when you turn on the car to cause then if you havent changed the plugs and wires on these cars, you should. the stock ones are junk.
Old Nov 28, 2007 | 01:39 PM
Burnnout's Avatar
Burnnout
They all shake a little when you turn them off.....she doesn't like it when you turn her off.
Old Nov 28, 2007 | 03:02 PM
dparsons06's Avatar
dparsons06
No it only does it when i shut it off, lol i like that, she doesnt want to be shut off
Old Nov 28, 2007 | 08:02 PM
srt4ACRboy's Avatar
srt4ACRboy
well i noticed a difference when i changed my plugs and wires in the amount the car moves when starting up, idleing, and shutting off! Alot smoother!
Old Nov 29, 2007 | 12:07 PM
whatneon's Avatar
whatneon
try depressing the clutch at shut down.
