Warranty
Old Nov 26, 2007 | 08:36 PM
lblackneon's Avatar
lblackneon
Default Warranty
Hi! Quick question.
The AC is covered under warranty right?
Old Nov 26, 2007 | 08:38 PM
faststage02005's Avatar
faststage02005
Default RE: Warranty
yup
Old Nov 26, 2007 | 08:42 PM
lblackneon's Avatar
lblackneon
Thanks! That's what I thought. I hope they don't try to give me a hard time because of the mods. If they do then that's BS.
Old Nov 26, 2007 | 10:24 PM
motorboy1's Avatar
motorboy1
Your 50 trim makes to much HP therefore turned the ac compressor to fast causing it to fail. Warranty void!!!
Just kidding hahayoushouldn't have a problem. Would be funny though if they tried it!
Old Nov 26, 2007 | 10:40 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
They can say your mods caused the a/c failure, it's up to them.....then you have to deal with the BS and the dealing back and forth. I had most of my work done by my dealer just to have that extra leverage in case it came down to legal issues.......but that's not 100% protection either.........either way, it's not fun.
Dusty
Old Nov 26, 2007 | 11:10 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
ORIGINAL: flamingpinhead
...anything they may bitch/gripe about with my mods or the fact I change my own fluids?
ORIGINAL: PSI Chick
they'll bitch that you own the car lol.
couldnt say it better
Old Nov 26, 2007 | 11:52 PM
PSI Chick's Avatar
PSI Chick
do you have solid mounts? if so that's a good reason for them not to warranty the a/c compressor. solid mounts put a strain on the belts which causes premature wear of the a/c. that's why it clunks and/or whines when you turn on the a/c.
Old Nov 27, 2007 | 01:23 PM
lblackneon's Avatar
lblackneon
I have the Agp motor mounts. I've never heard that sound because I bought the car from him with the AC not working.
Thanks for the inputs.
Old Nov 28, 2007 | 12:14 AM
motorboy1's Avatar
motorboy1
ORIGINAL: PSI Chick
How do mounts put a strain on the belts? just curious. I figured it always made that sound you just couldn't hear it with the softer factory mounts.
Old Nov 29, 2007 | 01:28 PM
lblackneon's Avatar
lblackneon
I don't want anyone messing with my parts. Is the H-brace and traction bars going to get in the way of fixing the AC? Will that have to be taken off?
