help wit ma stage 2 wastegate on how to adjust it
Old Dec 6, 2007 | 11:10 PM
daporkchop03's Avatar
daporkchop03
Default RE: help wit ma stage 2 wastegate on how to adjust it
so a 05 srt4 comes wit stage 1 fuel injectors already or i should get then
Old Dec 7, 2007 | 01:01 AM
PSI Chick's Avatar
PSI Chick
yes a stock turbo will hold 19-20psi, but again it has to be done right. i did 19psi on my stock turbo.
a bone stock car will benefit from a return line (with other supporting fuel mods of course), there is not a set hp range that you don't need it until. the purpose of a return line is to increase fuel and efficiency, it doesn't matter how lightly or heavily you're modded.
if you're looking for bigger injectors it would depend on what your future plans are for the car. are you going to go big turbo? s3? stay on stock turbo? ported/big wheel stock housing?
Old Dec 7, 2007 | 09:01 AM
daporkchop03
im planning on stayin on a stock turbo or to a t3/t4 turbo but as of right now im plannin on a stock turbo
Old Dec 7, 2007 | 03:18 PM
PSI Chick's Avatar
PSI Chick
not right now, what are your final goals? and a t3/t4 tells nothing other than what your flange is.
Old Dec 8, 2007 | 07:52 PM
daporkchop03
well im plannin on stayin on the stock turbo and i want to be at 19 steady so give me a sight so i can order the stuff i need
Old Dec 9, 2007 | 03:10 AM
faststage02005's Avatar
faststage02005
dtec, stage 2 injectors, wideband..return line and fuel rail will help too...
Old Dec 10, 2007 | 08:58 AM
Burnnout's Avatar
Burnnout
ORIGINAL: daporkchop03
AGPTurbo.com ......
Old Dec 11, 2007 | 09:49 AM
Kapitald's Avatar
Kapitald
modernperformance.com
