help wit ma stage 2 wastegate on how to adjust it
Old Dec 5, 2007 | 03:19 PM
daporkchop03's Avatar
daporkchop03
Default help wit ma stage 2 wastegate on how to adjust it
i juss put in ma stage two wastegate and i have a boost controller doin it at 20 psi's when i acceracte in sec it goes to like 15 and sometimes to 20 and third goes to 20, but it goes down to like 14 or a lil lower as the rpm's get closer to the redline, is that right or do i have to adjust it.
mods on car , boost controller, stock turbo 20psi, 3 inch o2 housing , 3 inch downpipe, 2.5 mopar exhuast, and stage 2 wastegate
Old Dec 5, 2007 | 03:33 PM
Burnnout's Avatar
Burnnout
Default RE: help wit ma stage 2 wastegate on how to adjust it
You do not have fuel to support the added boost....
Old Dec 5, 2007 | 08:57 PM
srtlouis's Avatar
srtlouis
sounds good the turbos on or srt are not big will not hold boost to redline what year is your srt..
Old Dec 6, 2007 | 12:07 AM
PSI Chick's Avatar
PSI Chick
they certainly will hold boost to red line, but you have to have it set up right, which he does not. i seriously suggest turning your boost down to 15 or 16psi, you don't have the fuel to support higher boost.
Old Dec 6, 2007 | 09:35 AM
daporkchop03
ma year of the srt-4 is 2005 wit 29200 miles
Old Dec 6, 2007 | 10:35 AM
PSI Chick's Avatar
PSI Chick
great you still don't have the fuel to support higher boost.
Old Dec 6, 2007 | 04:30 PM
daporkchop03
wat should i do.. wat kidn of fule injectors.. imma get it tuned in spring
Old Dec 6, 2007 | 05:20 PM
Burnnout's Avatar
Burnnout
Tuned with what ? If you are going to mess with boost you need a wideband (ex. AEM EUGO, Innovative ) , more fuel ( ex. injectors, return line, fuel pump ) , and a way to control it ( ex. SAFC, DTEC, AEM ).
Old Dec 6, 2007 | 06:17 PM
srtlouis's Avatar
srtlouis
a stock turbo will not hold 20lbs of boosst till redline
Old Dec 6, 2007 | 06:23 PM
srtlouis's Avatar
srtlouis
i would get a wide banband but you do not need a return line or less you are over 400hp... 05 have stage 1 injectors you can also use a map clamp too help tune
