Need a little advice
Old Dec 7, 2007 | 10:33 AM
hondaslayer05's Avatar
hondaslayer05
Default Need a little advice
wuts up guys new on here and i was just wondering does everyone else have problems with grabbing traction and if so what can I do to help it, that and im not sure why but in the mornings sometimes when the car is cold i will start it up and the oil light will come on but it has enough oil in it cause i checked it does it have to do with the weather? Thanks for your help
Old Dec 7, 2007 | 03:13 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Need a little advice
Have you considered motor mounts for your "grabbing" problem?
Dusty
Old Dec 7, 2007 | 04:09 PM
srt4ever's Avatar
srt4ever
Motor Mounts X2 FTW!!!!
Old Dec 7, 2007 | 07:05 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
What weight oil are you using and is it dino oil or synthetic?
Dusty
Old Dec 9, 2007 | 05:48 PM
hondaslayer05
5w 30 and its synthetic but i only does it when i start the car for the first time that day. and what type of motor mounts would you recomend.
Old Dec 9, 2007 | 06:59 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
How much do you want to spend? You can get AGP dogbone motor mounts for about $125..........Avid motor mounts will set you back almost $350.
Dusty
Old Dec 9, 2007 | 11:43 PM
lblackneon's Avatar
lblackneon
If u don't want to spend much money at all you can get Prothane motor mount inserts.
Old Dec 10, 2007 | 01:16 AM
PSI Chick's Avatar
PSI Chick
inserts are a waste of time, just get full mounts.
as for the oil thing, it's probably the oil pressure switch. it happens sometimes. it's a cheap and easy thing to replace.
Old Dec 10, 2007 | 12:45 PM
srt4ever's Avatar
srt4ever
Where is the oil pressure switch located? Any help?
Old Dec 11, 2007 | 10:41 AM
srt4ACRboy's Avatar
srt4ACRboy
ORIGINAL: dustyloins
Dusty
Avid is so expensive because it comes with upper, lower, and transmisson mount. Where dogbones come with upper and lower mount.
