been stock long enough
Old Dec 11, 2007 | 12:25 PM
Catholic Damage's Avatar
Catholic Damage
Default RE: been stock long enough
what about the wheel hop? any suggestions on that?
Old Dec 11, 2007 | 01:10 PM
Burnnout's Avatar
Burnnout
The solution to wheep hop is solid motor mounts.
Old Dec 12, 2007 | 11:57 AM
srt4ACRboy's Avatar
srt4ACRboy
^^^ what burnnout said, AGP seems to be the most popular ones to get!
http://www.modernperformance.com/pro...c367349350bffe
Old Dec 12, 2007 | 04:50 PM
Burnnout's Avatar
Burnnout
ORIGINAL: Kapitald
so stage two injectors...setup correctly....can hold18-20 psi strong???
that sounds good...thats what im looking for actually
also...PSIchick....whats wrong with the side exit exhaust in your opinion...it was already on my car when i bought it...
You need something to control the injectors.... i.e. the s2 computer.
I'm not sure if you can hold 18psi with the S2 w/g though... I used the agp and had no issues.
Old Dec 12, 2007 | 04:54 PM
Catholic Damage
**** it. stoge one. i dont want to put that much work into it.
just gonna do a cat back, intake, satge one tune, and boost it to 16psi.
Old Dec 12, 2007 | 05:50 PM
Burnnout's Avatar
Burnnout
If you're going to do exhaust I would really go with a turboback, stage one tune meaning you're going to go with the s1 ecu? Intake on this car doesn't give a hp gain just an FYI.... they def. free up engine space and sound nice though.
Old Dec 12, 2007 | 09:37 PM
srt4ACRboy's Avatar
srt4ACRboy
ORIGINAL: Burnnout
ORIGINAL: Kapitald
About the agp wastegate, if i have an 05 srt4, will i through a overboost code if i install on with just the mods I have? SRI, plugs and wires, OCC, bov? I know that the 04-05 come with stage 1 injectors but i was wondering?
Old Dec 12, 2007 | 11:52 PM
faststage02005's Avatar
faststage02005
yeah it will....since its an 05 you need to get a stage 1 to make the light go away....i have mine on my stage 0 2005 and i am spiking 18 dropping to 15 psi.....
Old Dec 13, 2007 | 08:08 AM
Burnnout's Avatar
Burnnout
If you boost over 16psi you will, but you don't have the fuel to boost anymore than that.
Old Dec 13, 2007 | 09:26 AM
Catholic Damage
ok, so a catless turbo back, forget the intake, ill just do a drop in K&N,, stage one tune, and boost controller to 16psi, and i'll be fine.
anything else needed for 16psi, other than the stoge one tune so i dont throw an overboost code?
