front emblem
Old Dec 17, 2007 | 07:28 PM
SRT4kid's Avatar
SRT4kid
Default front emblem
does anybody know how to take off the front emblem? i dont want to break anything
Old Dec 17, 2007 | 08:49 PM
blue_srt4's Avatar
blue_srt4
Default RE: front emblem
theres really nothing to break. emblems are usually trash after removing them anyways. u will need adhesive remover to remove the excess tape from ur bumper.
Old Dec 18, 2007 | 08:21 AM
srt4ever's Avatar
srt4ever
So are there screws behind it or is it just stuck on there with adhesive? Will a Viper emblem fit there? Thoughts....??? Do you think it would look OK or not..
Old Dec 18, 2007 | 11:54 AM
SRT4kid's Avatar
SRT4kid
This is were I will get a new one, 'M' SRT-4, he has others:
http://stores.ebay.com/24-Designs
Old Dec 18, 2007 | 11:59 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
should just be held on by adheasive. using a heat gun might make it much easier, as it 'loosens' the adheasive. then you can just peel the adheasive off, it will be gummy. then like mentioned above, use an adheasive remover to remve any residue.
Old Dec 18, 2007 | 12:23 PM
prpaster's Avatar
prpaster
i would use a hair dryer rather then a heat gun bc you can bubble the paint with a heat gun
Old Dec 18, 2007 | 12:29 PM
flamingpinhead
Section Moderator
used a heat gun for a couple years at the shop, never killed the paint with it. but use it like your ol lady uses her hair dryer, dont hold it in one spot too long and keep it on the low setting unless you really need hotter.
but yes, a hair dryer would work great as well if a heatgun isnt available. i know alot more households with a hairdryer than a heat gun
Old Dec 18, 2007 | 01:09 PM
STILL GH3TtO's Avatar
STILL GH3TtO
yes the viper emblem will fit i have one on my srt4
Old Dec 18, 2007 | 01:13 PM
STILL GH3TtO
and i could be wrong but i am pretty sure that it kinda clips on not adhesive. I took mine off a while back so i am not 100 % sure
Old Dec 18, 2007 | 06:22 PM
motorboy1's Avatar
motorboy1
ORIGINAL: STILL GH3TtO
Ithink so too.I believe it was like a 13mm sheet metal nut that held mine on along with tape.I just riped it off, the emblems was trash. Didn't hurt the bumper at all andI stuck my viper emblem right over the hole.
like so.... https://dodgeforum.com/photo.asp?pho...=6&apage=1
